Vinny_Vincenzo408 Posted November 18, 2013 Report Share Posted November 18, 2013 Looking to get new carbs for my banshee what's a good size to get? I ride at pismo dunes my mods so far are toomey t6 pipes vforce reeds advanced timing plate boost bottle Quote Link to comment Share on other sites More sharing options...
Pastrykiller Posted November 18, 2013 Report Share Posted November 18, 2013 Stocks are just fine. That motor is far from needing carb mods. 1 Quote Link to comment Share on other sites More sharing options...
Vinny_Vincenzo408 Posted November 18, 2013 Author Report Share Posted November 18, 2013 My stock carbs are done the threads on top of the carbs are stripped so I should get a new set of stock carbs? I'm planning on doing a 4 mill setup in the future if that would make a difference Quote Link to comment Share on other sites More sharing options...
Pastrykiller Posted November 18, 2013 Report Share Posted November 18, 2013 33 pwk's on a 4 mil is ideal. When u say tops are stripped...carbs or carb caps? I have a new set of tops if you need em. If not, I have a set of stock carbs that will have the new caps on them as well. Quote Link to comment Share on other sites More sharing options...
Pastrykiller Posted November 18, 2013 Report Share Posted November 18, 2013 Btw- pwk 33's and 35's have the same bodies. You can bore a 33 to a 35 if you need that size in the future. Quote Link to comment Share on other sites More sharing options...
Vinny_Vincenzo408 Posted November 18, 2013 Author Report Share Posted November 18, 2013 The carb is stripped. Would those be good if I were to run those on my setup for now? No thanks I'm still trying to decide if I should just save my money an start the 4 mil build Quote Link to comment Share on other sites More sharing options...
Vinny_Vincenzo408 Posted November 18, 2013 Author Report Share Posted November 18, 2013 Thanks that's good to know Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted November 18, 2013 Report Share Posted November 18, 2013 get some cheap stock carbs, and run them on the 4mm, when ever that happens. then buy bigger carbs later. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted November 18, 2013 Report Share Posted November 18, 2013 get some cheap stock carbs, and run them on the 4mm, when ever that happens. then buy bigger carbs later. I agree. Big carbs on a stock unported motor will make it a pig. Quote Link to comment Share on other sites More sharing options...
