Piediddy Posted November 17, 2013 Report Share Posted November 17, 2013 Guys bike runs fine for about 10 minutes till engines gets warmed up. Stock motor good compression, stock carbs jetted to fmf specs, +4 timing, fmfs, and K&N pod filters. Kinda feels electrical to me. What y'all think? Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
Finch Posted November 17, 2013 Report Share Posted November 17, 2013 "jetted to fmfs specs" have ya looked at the plugs to make sure its not to rich or lean? Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted November 17, 2013 Report Share Posted November 17, 2013 pick up gap on the stator(check with a feeler gauge) or float level may be the issue. Quote Link to comment Share on other sites More sharing options...
Piediddy Posted November 17, 2013 Author Report Share Posted November 17, 2013 I'm already down from a 260 main to a 240. Pilots are 30 should I try 27.5? Plug does look a little rich. I do need to check pick up gap. I got the bike from a buddy of mine and it sat for a while. After it cools bike runs fine again for about 10 or 15 minutes till it warms up again. Quote Link to comment Share on other sites More sharing options...
Sandking Posted November 17, 2013 Report Share Posted November 17, 2013 Double check your electrical ground. A lose ground caused these symptoms on one of my bikes Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted November 17, 2013 Report Share Posted November 17, 2013 More than likely electrical issue maybe cdi box or coil Sent from my SPH-L720 using Tapatalk Quote Link to comment Share on other sites More sharing options...
joey83 Posted November 18, 2013 Report Share Posted November 18, 2013 Cdi? Mine did that last summer. After it got warm woukd sputter and even die. It was the cdi Quote Link to comment Share on other sites More sharing options...
7211 Posted November 23, 2013 Report Share Posted November 23, 2013 could be cdi or bad stator my buddys 485 did the same thing an it was the stator if you let it sit for 15 min would run fine for a min or less untill it warmed up then would act like it was loaded up agin Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted November 23, 2013 Report Share Posted November 23, 2013 could be plug caps or wires. ohm the plug caps. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2013 Report Share Posted November 23, 2013 I've also had just old spark plugs do that. Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted November 23, 2013 Report Share Posted November 23, 2013 Fix the electrical issue if that's it, then recheck your plugs. Jetting sounds lean with pods. Depends where you are too I guess. Quote Link to comment Share on other sites More sharing options...
Piediddy Posted November 30, 2013 Author Report Share Posted November 30, 2013 I finally got a chance to work on the bike. I put one of those inline coil tester in place between plug and coil wire. Sitting on bike the left side cut out so bad the inline tester wasn't even lit up, also I noticed the left pipe wasn't half as hot as the right side? Quote Link to comment Share on other sites More sharing options...
tdod101 Posted December 14, 2013 Report Share Posted December 14, 2013 Top end Quote Link to comment Share on other sites More sharing options...
