Incurable Bog
Ok i got a shee with a Trinity c.v carb kit, fmf's and a few other miner things. The problem is i cant seem to fix the bog it has in the bottem end. So i took it to the shop and they said it sounded like it was runnin rich. After many tries they said that it wasnt responding to any jetting changes for that rpm range. They then thought i could be the reeds but they cheacked out fine. They eventually gave up and told me it must be something electrical. Now I have no clue what to do. Also it has 120 pounds of compression so i dont think that is the problem. Has anyone over herd of this or know what it might be.
dont know if this will help you. i had a bitch of bog and couldnt get the jetting corrrect. well i run pro design foam with an outerwear and what happened was the oil plugged up the wear so bad that it wouldnt get air. i doubt this is your problem.
what pilots and needle you using. position
What type of filter set-up are you running? Are you ported? Traditionally cv carburation systems require restriction through the filters and or air box in order for the cv portion of metering to operate properly. ...Jim
I have a pro flow intake with no airbox lid. When i pull the plugs they are wet and it shows other signes of running rich like backfiring. It bogs like hell bottom end then once it gets past that it pulls real hard and then it seems like it doesnt rev out like it should. Ive tryed leaning it out and it didnt work went all the way down to a 40 from a 48 and could see hardly any difference.
