alcohol to e85 carbs
flyn10
Probably not because you wont need as much fuel for E85 so the dump tubes are probably going to be drilled to large. Also E85 is not real consistan on the blend. One tank might be 70% ethanol 30% gasoline, and the next one might be 85% ethanol 15% gasoline. The swing in blends will require a jetting change where straight methanol is going to be 100% methanol every time.
They are. Yes. But it is inconsistent. I had a buddy with a porche powered sand rail on e85. Every time out to the dunes the fuel was different and required a bit of lap top tuning. Just call the fellas at livernois Motorsports. They were one of the forerunners of the e85, and quickly moved on. It can definitely be cool stuff no doubt. But we are talking about a banshee already set up for alky, so why put it on e85?
The efi programs can adjust on the fly for the irregularity that the fuel comes in. A carb relys on the nut behind the wheel to make those adjustments. Im assuming that if the op is asking he/she is not competent enough to make those adjustments correctly.
