amado814 Posted November 4, 2013 Report Share Posted November 4, 2013 I'm in the middle of redoing some electrical on my banshee and I wanted to run a simple on off switch in place of the oem cluster for my headlights and tail lights . Are any of you guys doing this already ? Pictures will be appreciated Quote Link to comment Share on other sites More sharing options...
Starwriter Posted November 4, 2013 Report Share Posted November 4, 2013 I haven't done it yet, but here is the schematic I drew up, if you want to keep high and low beams. You need a double pole, double throw toggle switch with a center off position. Make sure that neither of the positions are momentary. If you only want 1 beam,(aftermarket lights) you just need a simple single pole, single throw switch. You could make a bracket off the TORS box tab or any other place. Quote Link to comment Share on other sites More sharing options...
