Jrod324 Posted November 2, 2013 Report Share Posted November 2, 2013 K guys i finally had time to take my bike apart and found where the bike was leaking from now my question is in this picture is the bike suppose to be dripping fluid in there or is it a seal of some sort (because the idiot that worked on my bike put a piece of cardboard as a gasket and maybe thats why it was leaking....?) please give me your opinions thanks Quote Link to comment Share on other sites More sharing options...
Finch Posted November 2, 2013 Report Share Posted November 2, 2013 vent should have a line that comes off it and connects to the one off the back of the motor. but you can also just plug it. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted November 2, 2013 Report Share Posted November 2, 2013 There's not supposed to be a gasket between the cover you took off and the clutch cover. There shouldn't be any oil in that area. There should be a hose on that brass spout that you see in the pic. It should go through the hole in the clutch cover, up by the waterpump and then tee with the vent hose from the back, top of the cases. The tee should be somewhere above the carbs. Then the hose should go up to the steering stem hoop and loop back down a little ways. However... That brass vent that you are looking at is not needed. You can cap it off with a piece of hose, a ball bearing and a couple zip ties. The prefered way to block it off is with the $10 ebay billet block off plate. That does mean removing the clutch cover and pounding out that brass vent piece. http://www.ebay.com/itm/Banshee-Clutch-Cover-Vent-Block-off-Plate-/110747369144?pt=Motors_ATV_Parts_Accessories&hash=item19c90ebeb8&vxp=mtr Quote Link to comment Share on other sites More sharing options...
Vicstuff Posted November 2, 2013 Report Share Posted November 2, 2013 Sometimes the brass piece will pull out with a pair of pliers, at least mine did lol Quote Link to comment Share on other sites More sharing options...
Jrod324 Posted November 2, 2013 Author Report Share Posted November 2, 2013 vent should have a line that comes off it and connects to the one off the back of the motor. but you can also just plug it. There's not supposed to be a gasket between the cover you took off and the clutch cover. There shouldn't be any oil in that area. There should be a hose on that brass spout that you see in the pic. It should go through the hole in the clutch cover, up by the waterpump and then tee with the vent hose from the back, top of the cases. The tee should be somewhere above the carbs. Then the hose should go up to the steering stem hoop and loop back down a little ways. However... That brass vent that you are looking at is not needed. You can cap it off with a piece of hose, a ball bearing and a couple zip ties. The prefered way to block it off is with the $10 ebay billet block off plate. That does mean removing the clutch cover and pounding out that brass vent piece. http://www.ebay.com/itm/Banshee-Clutch-Cover-Vent-Block-off-Plate-/110747369144?pt=Motors_ATV_Parts_Accessories&hash=item19c90ebeb8&vxp=mtr K so i dont need that hose and can block it off with that billet plate? Or i need to get that hose again and install it? I have the manual so ill look at where it goes if i need it.... And as for a gasket theres not suppose to be one in there you say? Because last week when i rode and it got hot thats where it started to leak from and i thot it was from a worn gasket Quote Link to comment Share on other sites More sharing options...
Finch Posted November 2, 2013 Report Share Posted November 2, 2013 nope that piece just presses in can always pinch it closed and solder it to Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted November 2, 2013 Report Share Posted November 2, 2013 On a stocker it gets routed up and around between the carbs and t's with the line that comes from the back of the motor by the rear mount. Then they both go up to the handle bars next to the throttle cable. That's gonna puke fluid out the way it is now. It needs to be up above the fluid level if nothing else. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted November 2, 2013 Report Share Posted November 2, 2013 Duct tape or the stock hose... Done Quote Link to comment Share on other sites More sharing options...
camatv Posted November 2, 2013 Report Share Posted November 2, 2013 just put the hose back on it .. Quote Link to comment Share on other sites More sharing options...
Nieskes Posted November 2, 2013 Report Share Posted November 2, 2013 Take some solder and plug it off. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted November 2, 2013 Report Share Posted November 2, 2013 Pound 2 toothpicks in it and be done. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 2, 2013 Report Share Posted November 2, 2013 Pound 2 toothpicks in it and be done. You forgot the gorilla glue you Yutz! Quote Link to comment Share on other sites More sharing options...
2strokeshees Posted November 3, 2013 Report Share Posted November 3, 2013 put the hose on it... smh Quote Link to comment Share on other sites More sharing options...
03DMshee Posted November 3, 2013 Report Share Posted November 3, 2013 There is a nice rubber cap off of a volkswagen diesel injector that fits so perfect and tight you dont even need a clamp to hold it on...any vw dealer will have them in stock...50 cents Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted November 3, 2013 Report Share Posted November 3, 2013 Any small vacuum line cap will work. Or just run a screw in it. Also check your rear vent and make sure it's not clogged. Quote Link to comment Share on other sites More sharing options...
