SlowerThanYou Posted November 2, 2013 Report Share Posted November 2, 2013 I was just checked clutch steal plates and they are warped. Its a brand new fast clutch. Was the plates checked for warpage before installing them. Just from this thread & your past PMs. I see nothing glaringly wrong with your clutch set-up. The only thing that you haven't provided is the air gap. Your plate pictures doesn't show me enough heat to cause the plates to warp IMO. We get very little warpage in our plates & we run a lot more slip than what you are doing. Below, the plate on the left is how we ran our clutches. This is a good usable seasoned plate. We inspect them for warpage, cracks, thickness & prep them for re-service. You can see the little prep we did to the plate with a roloc scotch brite disc. The plate on the right is how our plates tend to look now when everything is correct. We are running more slippage than we did with the left plate, but it doesn't show. We have spent a lot of time modifying the whole set-up with some in-between round procedures. This helps manage the heat build-up better & results in longer friction life. Quote Link to comment Share on other sites More sharing options...
johstoncounty banshee Posted November 2, 2013 Author Report Share Posted November 2, 2013 Well did I just get 2 crappy still plates some how I wonder. Quote Link to comment Share on other sites More sharing options...
johstoncounty banshee Posted November 3, 2013 Author Report Share Posted November 3, 2013 They don't look that Bad to me either I just 2 of them warped really bad it will spring back and forth. My other plates I just recondition them Quote Link to comment Share on other sites More sharing options...
johstoncounty banshee Posted November 3, 2013 Author Report Share Posted November 3, 2013 . My old clutch I cleaned up. Quote Link to comment Share on other sites More sharing options...
johstoncounty banshee Posted November 3, 2013 Author Report Share Posted November 3, 2013 I did not check for warped plates before I installed them. They were brand new in the pack Quote Link to comment Share on other sites More sharing options...
