blown crankshaft bearing
TZ bearing cut trans or trans of your choice and replace all seals this is a must also you could do a shift star mod billet water pump impeller and gear and take a look at your clutch setup maybe a adjustable timing plate if u don't have one that's all I can think of at the moment lol
Max loads for the crank and tranny plus all the other tranny bearings. Get them from Tony at TDR.
Do any shifting mod you can afford or do your self. Shift star, bearing on the detent from mull or shift pro, shift shaft mod, drum bearing, cut the tranny.
Adjust the eccentric
Put an extra half moon in the crank grooves and the spot in the tranny
New clutch ball and pancake bearing, freshen up any dingy hardware.
Address the clutch and it's needs. Check the forks
