JDP421 Posted October 28, 2013 Report Share Posted October 28, 2013 Hey guys I'm running a +10 inch swingarm stock link, how can I lower the rear down maybe 1-2 inches? Without a lowering link, Shorter Marvin shaw? Thanks, Jordan Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
JDP421 Posted October 28, 2013 Author Report Share Posted October 28, 2013 Maybe a 12 inch shaw? Instead of 13 or 14 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
JDP421 Posted October 28, 2013 Author Report Share Posted October 28, 2013 can go look for a shorter shock. a lot of used work shocks floating around you can send out to get shortened and rebuilt... without a lowering link... you are pretty well limited to shock set up.... maybe a 12 inch shaw? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted October 28, 2013 Report Share Posted October 28, 2013 R6 or R1 shock will do that. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted October 29, 2013 Report Share Posted October 29, 2013 R1 or r6 shocks do work.. but I dont personally recommend them for a dune drag bike... just my opinion... not sure how a shaw does compared to one but the r6 shock doesnt give much of a ride comfort I didnt know you did a lot of dune/ dragging ? The "comfort" level depends on the length of swinger you put the R1/6 shock on. I run one on a +10 and i have no complaints as far as "comfort" go. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted October 29, 2013 Report Share Posted October 29, 2013 If you run it on a link there's enough travel for your average dune-drag racer. I hit plenty of whoops @ LS with out bottoming out...and they weren't too little and the speeds were pretty good too. Sent from my SCH-R970 using Tapatalk Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted October 29, 2013 Report Share Posted October 29, 2013 Dont get me wrong, an R6 wont compare to a STD travel float or comparable quality shock, but it'll get you low and give you enough travel for everyday sand drags. Sent from my SCH-R970 using Tapatalk Quote Link to comment Share on other sites More sharing options...
slobanshee Posted October 29, 2013 Report Share Posted October 29, 2013 Was Using an r6 shock on my old ladies bike with a +10 on it. She's about 110lb and it's to soft and bottoms out. With her +6 it was fine. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted October 29, 2013 Report Share Posted October 29, 2013 R1 or r6 shocks do work.. but I dont personally recommend them for a dune drag bike... just my opinion... not sure how a shaw does compared to one but the r6 shock doesnt give much of a ride comfortNot good for the riding we do, but the R6/R1 shocks happen to be awesome on a +10 arm like the OP is using. A guy I know has an R1 shock on a +12 and it is quite different. OP, you can do a Lowering Link for cheap, R6/R1 shock for a couple more bones( I have a mint one if you are interested). The next cheap option is a warrior dog bone. If you were handy you could even try making a strut. After that it can get pricey. Custom length Marvin shaw, find a nice rebuilt stocker that has been set up for a 10/12" swinger, a used shock you have sent out and set up for you, aftermarket shock used or even new. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted October 29, 2013 Report Share Posted October 29, 2013 Not good for the riding we do, but the R6/R1 shocks happen to be awesome on a +10 arm like the OP is using. A guy I know has an R1 shock on a +12 and it is quite different. OP, you can do a Lowering Link for cheap, R6/R1 shock for a couple more bones( I have a mint one if you are interested). The next cheap option is a warrior dog bone. If you were handy you could even try making a strut. After that it can get pricey. Custom length Marvin shaw, find a nice rebuilt stocker that has been set up for a 10/12" swinger, a used shock you have sent out and set up for you, aftermarket shock used or even new. Yep^. Funny how real world experience changes things. +10 and a NEWER R6/R1 is a very good budget combo. I liked it better than a lowering block because it doesn't drop the shock link down where it can drag in the sand and bottom out. It'll work on a +12 too,,if you aren't too heavy and the spring and shock are in good shape..but itll take all the preload you have more than likely. I'm 210lbs in gear and run 1/2 the preload on the shock (2009 R6) with a +10 and stock link. I don't bottom out and my swinger sits just barely above level. Like i said earlier, it doesn't bottom out over some nasty whoops,,but i wouldn't jump it either ( why you would jump a +10" i dont know.) Quote Link to comment Share on other sites More sharing options...
