Just got new carbs . With FMFs K&Ns 19cc Domes at Sea Level, What jets should I be running?    Thanks
what kind of carbs??? what size?? which k&N (s)?? Did you get the twin filters or just the single in the air box?? If your still running the air box, then is the lid still on?? or modified??
Thanks for the response.
30mm Keihin Clones , twin K&N's with no airbox , forgot to mention also V Force Reeds.
W/ stock porting, I'd guess around a 165-170 main, needle in the 4th clip from the top, 50 pilot or 48, try both....this is a guestimate, but should be close....
