What sprockets to run?
BAMF87
Sheerider is right.
Definitely depends on your set-up.
14/41 is stock gearing and is what I run.
I read in another thread that you're running a 13T front sprocket.
Going up 1 tooth in front is like going down 3 teeth in back.
With a 14T front sprocket, that dune port motor will require
a lot more clutch fanning to keep it on the pipe than what you're
used to with the 13T but you'll have a lot more top end.
When my Shee only had T5 pipes and a port I ran 14/44 with 20x10x10 Skat Trak Edge's and liked it.  It gave me more bottom end power.  Riding the dunes at Glamis I rarely used 5th gear.  Now with a 4 mil stroker i'm using 14/41 (stock) gearing with the same Skat Trak tires and will most likely go to 13/41 gearing for more bottom end power.
