BAMF87 Posted October 28, 2013 Report Share Posted October 28, 2013 What's a good combo for all around dune riding on a dune ported she? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted October 28, 2013 Report Share Posted October 28, 2013 14-15 / 41 Depends on tire size, power out put, how much spin you want, everyone is different. I have a 15/41 on my dune bike. Quote Link to comment Share on other sites More sharing options...
do-work-son Posted October 28, 2013 Report Share Posted October 28, 2013 I run a 13/44 on my mine with 22" paddle . I don't spend a lot of time in sixth wide open I do a lot of hill shoots an playing around so that gearing works great for me Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted October 28, 2013 Report Share Posted October 28, 2013 Sheerider is right. Definitely depends on your set-up. 14/41 is stock gearing and is what I run. I read in another thread that you're running a 13T front sprocket. Going up 1 tooth in front is like going down 3 teeth in back. With a 14T front sprocket, that dune port motor will require a lot more clutch fanning to keep it on the pipe than what you're used to with the 13T but you'll have a lot more top end. Quote Link to comment Share on other sites More sharing options...
BAMF87 Posted October 28, 2013 Author Report Share Posted October 28, 2013 Thanks I'll put a 14 on see how it feels. My rear is 41 already. Quote Link to comment Share on other sites More sharing options...
Mighty Shee Posted November 2, 2013 Report Share Posted November 2, 2013 When my Shee only had T5 pipes and a port I ran 14/44 with 20x10x10 Skat Trak Edge's and liked it. It gave me more bottom end power. Riding the dunes at Glamis I rarely used 5th gear. Now with a 4 mil stroker i'm using 14/41 (stock) gearing with the same Skat Trak tires and will most likely go to 13/41 gearing for more bottom end power. Quote Link to comment Share on other sites More sharing options...
