Stator Testing
Got to thinking. (I got a headache while thinking). Is the stator supposed to grounded while testing the lighting side(black to yellow wires) of the stator. I was checking my mine in a freestate. Will this give me a false reading??
Edited by wayne_smith97
You don't even have to have the yellow and black wires hooked up for it to run, so I'd imagine you wouldn't need them to test the primary coil either. I've seen them test all over the place and still work, but you know if you have a waaaay off number that is toast. Is it Oem?
So i got my new stator and adjustable timing plate in and installed them and still no fire!!!!!!!!!!!!!!!!!  I attached some pictures and yes the stator was good. I unhooked and jumped the key switch and unhooked and disassemble the kill switch. The coil seems to test out on the ohm meter. What Now!!!!!!! The only thing i can think of is cdi. Thoughts? I was going to upload pics but it wont let me.
