First banshee ever! What to do?
Hey guys im new to these forums and banshees all together. I just picked up a 1987 banshee as a project as ive never had one of these before and it was all in boxes when i got it. I have almost everything to put it together so i want to do it as a project even if it takes me yrs.
So far i have painted the frame and j arms and put the front end together. Still waiting for the guy i got it from to get me the rear end parts so it can start to be a roller, i have most of the engine.. I need cylinders and the motor has to be rebuilt. Thats where my first question comes in.
What way should i go with the engine rebuild? Should i go all out and do a stroker kit or should i just do a stock rebuild? Im looking for the most reliability but still trying to get some good power out of it. Can anyone suggest what i should do for the motor?
This is what i have done so far
Edited by banshee1983
Pretty flexible on the budget as i plan to make this a long term project. Reasonable price i guess. I guess when all said and done probably 1000-1500 on just the motor if i can get away with that. I dont reallly have any specific plans for the bike. Just good low to mid range power. All around use for around my land and some country riding. I dont race just play .
4mil is a good option, if yours needs crank bearing who knows how much longer the rod bearings are going to last.
Things you should need are
4 mil crank
domes and coolhead
Stroker pistons
pancake bearing
Oil seals
Gaskets
Adjustable timing plate
porting for the 4mil
Good clutch
Right pipes
What pipes have you got?
I like pro circuits for your style of build
You will be fine with stock carbs but its nice to get rid of the tors.
4 mil crank
domes and coolhead
Stroker pistons
pancake bearing
Oil seals
Gaskets
Good clutch
Right pipes
/\  plus
new water pump
timing plate
case saver
You MAY be able build the motor correctly for 1500.  But.....that is if your being a real thrifty buyer and waiting for the right deal.  Just remember though....when buying a 4mil set of jugs.......you can run a 4mil crank with stock cylinders (obviously you need a different head to clear the extra stroke length)....however it will not run great.  It will be like putting a v-8 into a geo metro and then pulling 4 spark plugs and driving it.  So.....if you get a 4 mil crank......try and find either a set of pre-ported cylinders, or get a nice set of stock cylinders and have them ported.
4 mil crank
domes and coolhead
Stroker pistons
pancake bearing
Oil seals
Gaskets
Good clutch
Right pipes
I would really like to get the dmc 916's.
Can all these parts u named off be bought on ebay? And can i get some kind of kit thag includes all the seals and bearings so i dont have to buy everything all seperate? I really apreciate the help. This site is awesome
FYI your budget of 1500 will prob turn into 25-3000. Do it right the first time. Use the site sponsors
Damn. Yeah i wanna do it right the first time. Its gonna be a long project either way. Im being patient and writing everything down. Once i get the roller all built i will concentrate on the engine. I want it to be sick.
I would really like to get the dmc 916's.Can all these parts u named off be bought on ebay? And can i get some kind of kit thag includes all the seals and bearings so i dont have to buy everything all seperate? I really apreciate the help. This site is awesome
DO NOT USE FACKING EBAY! Call a couple sponsors on here, figure out who you want to use and buy from them. Better prices than ebay and they have a phone to call when you have questions.
ok thanks.. i will look into the sponsors.. is there any of them that u preffer? i have never built a wheeler before. i have built a few bikes but never went down into the motor like i have to this one.. i want it to be done right and run right.. i have alot of work ahead of me but its a banshee.. i have always wanted one growing up..
