Jram2088 Posted October 27, 2013 Author Report Share Posted October 27, 2013 You could buy a used set of stockers pretty cheap and save yourself a ton of money. I have several sets and I know lots of other guys have them also. You never did say what mods were done to your bike?? So I ended up buying the stockers got a good set for 100 both, my mods are CPI pipes vforce reeds and reg air filter no air box , what jetting should I run on those carbs ? Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted October 27, 2013 Report Share Posted October 27, 2013 What's your elevation and air temp? Are you going to run K&N's w/Outerwears, (a.k.a. pods) directly on the carbs? You can see my mods and jetting at sea level. Lean out your main jets 1 size for every 2000ft. I would start w/27.5 pilot jets and needle clips in the middle groove and at the very least 300 mains. If your motor is ported then go with what your builder suggests. Which would probably be 30 pilots, needle clips in middle groove, air screws 1.5 turns out and 330 mains at sea level. Quote Link to comment Share on other sites More sharing options...
Jram2088 Posted October 29, 2013 Author Report Share Posted October 29, 2013 What's your elevation and air temp? Are you going to run K&N's w/Outerwears, (a.k.a. pods) directly on the carbs? You can see my mods and jetting at sea level. Lean out your main jets 1 size for every 2000ft. I would start w/27.5 pilot jets and needle clips in the middle groove and at the very least 300 mains. If your motor is ported then go with what your builder suggests. Which would probably be 30 pilots, needle clips in middle groove, air screws 1.5 turns out and 330 mains at sea level. Wow that is great info thanks a lot i appreciate that I live in Miami so I'm under sea level and I'm just running uni filters directly on the carbs also the carbs have the tors removed Quote Link to comment Share on other sites More sharing options...
BUILDER Posted October 29, 2013 Report Share Posted October 29, 2013 Strm Trp has given you some good jetting advice! With your pipes and the filters you are running with stock carbs I would run a 290 main and a 27.5 pilot and it should be damn close. Quote Link to comment Share on other sites More sharing options...
Kadair_517 Posted October 30, 2013 Report Share Posted October 30, 2013 . Quote Link to comment Share on other sites More sharing options...
