Splitting cases / what's the easiest way?
Never drive wristpin out! The loading/blows can crack lower needle cages, and the rollers mar the big end of the rod. Pin puller-one of these times you won't 'get away' with driving the pin out :) And don't stick items in the rod's little end to hold them-similar stresses to the lower cages, not to mention marring the little end.
An impact wrench is just fine on the retaining nut on the bench. But in the case it's best to hold the flywheel so the 'blows' of the impact don't get transferred through to the bearings-(same effect as 'knocking the wrist pin out) Again, don't hold it by the rods for this either :)
I have a ton of gears, and can build up/weld your crank, no problem.
  • Like 1
