Budweiserallday Posted October 22, 2013 Report Share Posted October 22, 2013 Gonna take appart my bottom end tonight and was wondering if I should take my pistons off ? The clymer Manual says to flip the motor over on your work bench to take the bolts off on the bottom of the motor and I was wondering if the weight of the motor would hurt them or should I just put the pistons at the same height and let the weight sit on the head studs ( first time taking a banshee apart just don't want to fuck it up) thanks Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 22, 2013 Report Share Posted October 22, 2013 What are you actually going to work on/replace? Do NOT just set the motor on the pistons. If you're pulling the crank, the pistons have to be removed anyway. If you're rebuilding the top end, the pistons have to come off. If you're only working on the trans, you shouldn't have removed the cylinders. 1 Quote Link to comment Share on other sites More sharing options...
Budweiserallday Posted October 22, 2013 Author Report Share Posted October 22, 2013 What are you actually going to work on/replace? Do NOT just set the motor on the pistons. If you're pulling the crank, the pistons have to be removed anyway. If you're rebuilding the top end, the pistons have to come off. If you're only working on the trans, you shouldn't have removed the cylinders. Thanks for replying , I'm putting in a right side crank seal and checking the bottom end for anything worn , the guy I bought this bike from didn't put a crank seal in the right side . So I should just pull them off anyway ? Or can I wait till I pull the crank ? Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted October 22, 2013 Report Share Posted October 22, 2013 Thanks for replying , I'm putting in a right side crank seal and checking the bottom end for anything worn , the guy I bought this bike from didn't put a crank seal in the right side . So I should just pull them off anyway ? Or can I wait till I pull the crank ? it takes about 5 more minutes to pop the pistons off. 1 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted October 22, 2013 Report Share Posted October 22, 2013 If he put a crank seal in wrong, I'd check everything else too 1 Quote Link to comment Share on other sites More sharing options...
Budweiserallday Posted October 22, 2013 Author Report Share Posted October 22, 2013 If he put a crank seal in wrong, I'd check everything else too That's exactly what I'm doing , idk how you forget to put a crank seal in .. But everything internal is new or rebuilt so I figure it would be worth going through and making sure everything's aight Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 23, 2013 Report Share Posted October 23, 2013 Pull the pistons off so you can remove the crank completely from the cases for inspection. That will also make reassembly much easier. You're supposed to replace the wrist pin circlips with new ones any time you remove them. Some people probably reuse the old ones, but I never take chances. Put the split of the circlip either up or down. Never put it at 3:00 or 6:00. Mark the pistons so they go back in the same bores. When you have the crank out, check to make sure that the crank pins are welded. If they're not, send the crank to a builder to be trued and welded. If the previous owner is that much of a moron, I would replace the left side seal too. Who knows if he nicked the seal surface or something. Read this thread. It will help you a bunch. http://bansheehq.com/forums/index.php?showtopic=140912 1 Quote Link to comment Share on other sites More sharing options...
Budweiserallday Posted October 23, 2013 Author Report Share Posted October 23, 2013 Pull the pistons off so you can remove the crank completely from the cases for inspection. That will also make reassembly much easier. You're supposed to replace the wrist pin circlips with new ones any time you remove them. Some people probably reuse the old ones, but I never take chances. Put the split of the circlip either up or down. Never put it at 3:00 or 6:00. Mark the pistons so they go back in the same bores. When you have the crank out, check to make sure that the crank pins are welded. If they're not, send the crank to a builder to be trued and welded. If the previous owner is that much of a moron, I would replace the left side seal too. Who knows if he nicked the seal surface or something. Read this thread. It will help you a bunch. http://bansheehq.com/forums/index.php?showtopic=140912 Thanks for the info mane appreciate it Quote Link to comment Share on other sites More sharing options...
Budweiserallday Posted October 23, 2013 Author Report Share Posted October 23, 2013 Took my pistons off last night .. And they have never been run , does it matter witch one goes in witch bore? Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 23, 2013 Report Share Posted October 23, 2013 It really doesn't matter, since they've never been ran. I made a mistake on the previous post. I meant never put the circlip split at 3:00 or 9:00. Always put it at 12:00 or 6:00. 1 Quote Link to comment Share on other sites More sharing options...
Budweiserallday Posted October 23, 2013 Author Report Share Posted October 23, 2013 My frames Quote Link to comment Share on other sites More sharing options...
Budweiserallday Posted October 23, 2013 Author Report Share Posted October 23, 2013 Can post pics of the internals soon .. Gonna do it tonight since last night I didn't have a 32 mm socket .. Quote Link to comment Share on other sites More sharing options...
03DMshee Posted October 25, 2013 Report Share Posted October 25, 2013 I dont see a buweiser anywhere in the picture! 1 Quote Link to comment Share on other sites More sharing options...
03DMshee Posted October 25, 2013 Report Share Posted October 25, 2013 *Budweiser Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted October 25, 2013 Report Share Posted October 25, 2013 Took my pistons off last night .. And they have never been run , does it matter witch one goes in witch bore? Have the cylinders been bored? Did they get honed to the piston size? If so it'll make a difference. I think a previous post said to make sure not to mix up pistons per side. Quote Link to comment Share on other sites More sharing options...
