thesoultaker2117 Posted October 18, 2013 Report Share Posted October 18, 2013 My drag banshee keeps pinching electrodes shut on the spark plugs. Compression is about 175. Plugs burn perfect color. Any idea on why this is happening and a solution? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted October 18, 2013 Report Share Posted October 18, 2013 Deto big time or you have a bad rod bearing. What type of fuel are you running? What is your timing? Quote Link to comment Share on other sites More sharing options...
thesoultaker2117 Posted October 19, 2013 Author Report Share Posted October 19, 2013 No detonation. And no possible way the piston is slapping the plugs......its occuring in both cylinders Quote Link to comment Share on other sites More sharing options...
Nieskes Posted October 19, 2013 Report Share Posted October 19, 2013 Pics? 1 Quote Link to comment Share on other sites More sharing options...
thesoultaker2117 Posted October 19, 2013 Author Report Share Posted October 19, 2013 Its almost as if the electrode is becoming red hot and the compression is pushing it into the post. It does it on both the iridium-ngk br8eix and the normal b8es plugs. I even spaced the plugs up using compression washers. My squish clearance is 55 thousandths and the domes are herrs jugs specials. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted October 19, 2013 Report Share Posted October 19, 2013 Its almost as if the electrode is becoming red hot and the compression is pushing it into the post. It does it on both the iridium-ngk br8eix and the normal b8es plugs. I even spaced the plugs up using compression washers. My squish clearance is 55 thousandths and the domes are herrs jugs specials. picture of plug would help. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted October 19, 2013 Report Share Posted October 19, 2013 Well, I will say, said builder did supply me with the wrong domes. Needless to say, I am not going back. Even after I called with concerns about the specs and numbers I got. They were just not compatible with my motor. Luckily/thankfully the clutch/trans let go. Went to a different builder, he was not impressed. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted October 19, 2013 Report Share Posted October 19, 2013 Deto big time or you have a bad rod bearing. What type of fuel are you running? What is your timing? I will stick with this. Please keep us updated. Quote Link to comment Share on other sites More sharing options...
thesoultaker2117 Posted October 19, 2013 Author Report Share Posted October 19, 2013 I was thinking domes. Maybe wrong angle or something but wasn't sure. Thanks for the great tips and help. Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted October 19, 2013 Report Share Posted October 19, 2013 can electrodes physically close up without contact? Quote Link to comment Share on other sites More sharing options...
mailman Posted October 19, 2013 Report Share Posted October 19, 2013 yes Quote Link to comment Share on other sites More sharing options...
SlowerThanYou Posted October 19, 2013 Report Share Posted October 19, 2013 Deto big time or you have a bad rod bearing. What type of fuel are you running? What is your timing? I will stick with this. Please keep us updated. I agree with n2o! He didn't answer the fuel or timing ?. Quote Link to comment Share on other sites More sharing options...
camatv Posted October 19, 2013 Report Share Posted October 19, 2013 deto. simple. something wrong with the dome profile or too much timing. it is basically hammering so hard and quick it just closes the gaps on the plugs no time to shake the motor and shoot them out . it could be a major lean out at wide open throttle from bad fuel delivery also? Quote Link to comment Share on other sites More sharing options...
thesoultaker2117 Posted October 19, 2013 Author Report Share Posted October 19, 2013 I'm running c-12 from vp. Timing is at 96 thousandths advanced. I run a pvl. 68 mm cub. Vf4s porting initially done by passion and then re done because it was crap. Port timing is to mat shearer specs. Domes are from hjr. 18cc. About 165-175 on compression and 55 thousandths on my squish clearance. I am not exactly sure of the squish angle nor the percentage it takes up. I run 500ft dirt and by the finish of my second pass......one or both plugs are smashed shut. Quote Link to comment Share on other sites More sharing options...
Redline Racing Posted October 19, 2013 Report Share Posted October 19, 2013 Back off timing to .080". Quote Link to comment Share on other sites More sharing options...
