right side cylinder spark plug keep backing out
fastbshee
I have a 421 cheetah cub on gas and when I first took it out never had the spark plug start backing out before until last weekend I have the power head with 23 CC custom cut domes and my timing is on plus two.basically trying to troubleshoot and see what could be causing this problem. can anyone help me thanks
Keyway airleak?
I dunno why I was thinking flywheel keyway.
drive keyway usally leaks oil and smokes a ton out of that side.
either way I would still check that your getting good fuel flow by clearing out the gas cap vent and checking float height on both carbs.
leakdown with tell you if its an airleak
  • Like 1
do a leakdown test. it will ensure that your not detonating from being lean....
Then do another compression test.  Make sure your holding the throttle all the way open and kick until that needle stops moving.
If both those check out good.......grab your self a 6"x6" piece of plexi-glass, some greese, and a drill bit.  Pull your domes.  Drill a hole just off to the side of the center of the plexi-glass.  Then put a spark plug in the dome and press it to the glass so that the drilled hole is semi near the sealed lip of the dome.  Then fill with water until you can see that there is no air bubble AND that the water is not coming out from being too full.  This is how you check the cc of a dome.
Not doubting brandons abilities.....but we're all human and all make mistakes sometimes.  Doubt its a problem from him.....that's why this is the last option.
please explain this process on a dome that is stepped for a stroker motor
Well you'd minus the 2 mm step and the area of the bore fo say a 4 mill. But for this 421 cub doesn't need stroker domes as the height needed is in the cyls. But just finding a cc won't solve all dome issues squish/band/angle can all play a rule. But where its a new problem not from day one I doubt its a dome issue.
