Wtb banshee rear brake switch
Alex29573
Screw that hokey ass Yamaha design. Just get a banjo bolt switch and be done. If you're retrofitting an earlier bike with the OEM switch, you need the switch with mounting bracket, spring, link, clutch cover bolt hook thing, and the brake pedal. Or you have to weld a tab on your early brake pedal.
http://www.ebay.com/itm/Motorcycle-Hydraulic-Brake-Switch-10x1-25mm-Wire-Replaces-Banjo-Bolt-with-Washer-/231030637876?pt=Motorcycles_Parts_Accessories&hash=item35ca7fc534&vxp=mtr
