wayne_smith97 Posted October 19, 2013 Author Report Share Posted October 19, 2013 Ok guys bought a new multimeter. checked stator ignition coil 17.1 ohms. pickup coil 111.2 ohms. Terminal to terminal on coil i got 0.4ohms. i didnt know how to check secondary on the coil. What next??? Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted October 19, 2013 Author Report Share Posted October 19, 2013 Anybody Quote Link to comment Share on other sites More sharing options...
nightmarebanshee Posted October 19, 2013 Report Share Posted October 19, 2013 i think the ohms is off on that coil...try and find the page on here that tells you what it should read...i think its around 7-9 but id try and find it..it will tell you the other readings too Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted October 19, 2013 Author Report Share Posted October 19, 2013 That post said .26 - .38 primary 7000 - 9000 secondary dont know how to check secondary though Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted October 20, 2013 Author Report Share Posted October 20, 2013 I gey good readings for the pick up and ignition side of the stator, but when i check the lighting side black and yellow wires i get no ohm reading whatsoever. Does this definately make iy bad. My thinking is yes because the cdi and coil pull some electricity. Right?? Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted October 21, 2013 Author Report Share Posted October 21, 2013 Come on guys Quote Link to comment Share on other sites More sharing options...
SandSlingerOR Posted October 21, 2013 Report Share Posted October 21, 2013 Im having erractic spark issues with my 89 after it sat for two years. Im down to a cdi possibly being bad. Have you tried to swap out yours yet? Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted October 21, 2013 Author Report Share Posted October 21, 2013 No i dont have anyone i know that rides a shee. Dont really wanna buy one if i dont know for sure. Know what i mean. Quote Link to comment Share on other sites More sharing options...
SandSlingerOR Posted October 21, 2013 Report Share Posted October 21, 2013 Exactly hella expensive for one. My buddy's banshee lost spark randomly & the cause was the key switch failed, water or somthing got into that.if you have a key switch might want to cut out. Also somtimes wires around cdi box in the back seem to get rubbed together & cause a short. Check all that out as well. Quote Link to comment Share on other sites More sharing options...
KaN Powersports Posted October 21, 2013 Report Share Posted October 21, 2013 Ohm the stator to ground as well. I have seen the coils pass the ohm test, but also have continuity to ground (shouldn't)... Make sure it is unplugged to do this, cause if you have a faulty switch somewhere, it could trick you into thinking you need a new stator. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted October 21, 2013 Author Report Share Posted October 21, 2013 I metered it black to yellow and then yellow to frame. Is this what you mean? I assumed that since the black wire has a ground terminal on it. Quote Link to comment Share on other sites More sharing options...
