BeeCanBanshee Posted October 9, 2013 Report Share Posted October 9, 2013 So I'm building a drag bike and want to know if shearer inframes or any inframe drag pipe will make the same power as there oof counter parts if you ran the inframes with just longer stingers? Like Tyler's bikes are, I imagine he runs his that way for hill climbs but I've seen some local guys run there bikes that way at the track and was curious as to how they compare to oof pipes. It's not a must for me to run that way I'm just curious and I think its nice looking. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted October 10, 2013 Report Share Posted October 10, 2013 I don't think it wold be exactly on par but within a few ft lbs and HP. It's loud though, and I'd imagine that if you're just doing stinger tube there is something to be had by figuring out the right diameter and length...... Quote Link to comment Share on other sites More sharing options...
possum Posted October 10, 2013 Report Share Posted October 10, 2013 inframes and outters are completly different pipes and will never be close to the same. As I have been told. Quote Link to comment Share on other sites More sharing options...
fappy'97 Posted October 10, 2013 Report Share Posted October 10, 2013 inframes and outters are completly different pipes and will never be close to the same. As I have been told. Hmm, in what way? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 10, 2013 Report Share Posted October 10, 2013 Shape, size and length. Quote Link to comment Share on other sites More sharing options...
BeeCanBanshee Posted October 10, 2013 Author Report Share Posted October 10, 2013 Shape, size and length. So sb/sf oof head pipes are a different shape than there inframe head pipes? I figured the main difference would be the bend coming off the head. And I would think as far as how loud it was it would be the same as unsilenced oofs. And tuned length I imagine makes a difference but replacing the inframe stinger/silencer combo with a same length straight stinger might be close to the same as a oof stinger section. Quote Link to comment Share on other sites More sharing options...
Pasi S. Posted October 10, 2013 Report Share Posted October 10, 2013 I´m not a Banshee Expert. Quote from SandSlingers: Posted 15 June 2013 - 10:10 AM It really depends on the engine set up. For example on my personal 4 mm cub inframe vs drag is almost 10 hp difference but on my 350 inframes are 3 pk hp better and also have 500 rpm more usable power. So there really isn't a direct answer. I will tell you that both pipes are completely different and require very different engine setups. I could give you some advice if you want to tell me your setup or you could call me.. 1 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted October 10, 2013 Report Share Posted October 10, 2013 On my 18DM, the Shearer out-frames for my motor only made about 5hp more than my in-frame setup. The curve looked better with my in-frames. Quote Link to comment Share on other sites More sharing options...
BeeCanBanshee Posted October 10, 2013 Author Report Share Posted October 10, 2013 Is it more or less trial and error as far as inframes having a better curve or do most inframes have a better curve. And also since you have a pretty big motor the difference in hp will be bigger correct. And also who or what did you use to make the inframe straight stingers? Also is there even any power difference between the inframes with stingers and silencers vs the inframes with straight through stingers no silencer? Quote Link to comment Share on other sites More sharing options...
Hazzard Racing Customs Posted October 26, 2013 Report Share Posted October 26, 2013 Tyler im also curious on this note with that 20mm DM he is also running straight stingers on it is that something Cam recommends on the bigger motor hill climb bikes? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted October 26, 2013 Report Share Posted October 26, 2013 Tyler im also curious on this note with that 20mm DM he is also running straight stingers on it is that something Cam recommends on the bigger motor hill climb bikes? It all started when Cam built our first 18DMs. We were the first to put that big of a motor in a hillclimb bike. We knew we needed an out-frame style pipe, just in an in-frame version. Cam shot me the idea and I went with it. I changed my flange and brought the stinger out to a certain length and it worked. Now all of the ones he builds for hill climbers are set up that way. Quote Link to comment Share on other sites More sharing options...
