Clutch problems
Hi guys im new to the gorum and I'm having some problems with my modified 03 shee. She ran like a top at the start of the year then all of a sudden the cable got loose. So I loosened the adjuster on the perch until the lever was at the right position. But I noticed that it was almost screwed out all the way. So I thought stretched clutch cable and bought a new one and installed. The old one didn't look stretched so I had the same result. Took it out for a ride and the clutch wouldn't disengage. Ok?! so i pulled the cover off and tightened the nut to right spec according to the clymer manual. Put it all back together and took it for a ride and about fifteen minutes later it wouldn't engage, I couldn't move the lever. So after I pushed it back to the house i found the little arm on the engine that u connect the cable wouldn't move. So wat is going on?! The guy who built my engine (who did an amazing job by the way) is 5 hours away. It's been 3 years since he built it and this is the only thing that ever went wrong. Thanks guys and I'm happy to be part of the forum
