bean94_125 Posted November 5, 2003 Report Posted November 5, 2003 Hello having some problems with jetting, i was wondering if any one has some what of idea as to what settings the carbs should be. such as pilot jet, main, and air screws.I live in michigan and looking for temp around 50. My banshee has been bored (FRESH) less than 3 hrs on new top end. 0.20 thousandths, boysen rad valves-with carbon fiber reeds, carbs are 28mm mukuni's, boost bottle, pro curcit pipes and forrest approved spark arrestors. also i have a K&N air filter and has 6 holes in the lid. also running stock plugs. Quote
Banchetta Posted November 5, 2003 Report Posted November 5, 2003 Hello having some problems with jetting, i was wondering if any one has some what of idea as to what settings the carbs should be. such as pilot jet, main, and air screws.I live in michigan and looking for temp around 50. My banshee has been bored (FRESH) less than 3 hrs on new top end. 0.20 thousandths, boysen rad valves-with carbon fiber reeds, carbs are 28mm mukuni's, boost bottle, pro curcit pipes and forrest approved spark arrestors. also i have a K&N air filter and has 6 holes in the lid. also running stock plugs. I can't remeber his exact jetting, but pm Chase73. He has the same setup as you exept he has porting....I believe he has 35 pilots, 175 mains, but not definate. BTW, he liked his stock carbs better....Has problems getting his perfect too... Quote
