broken piece off of dome !
Jaystre
it is a dome with a o-ring groove ...didnt put that much grease i would think . piston and cylinder are fine but the o-ring on the other dome was starting to  break up at the same spot above the exhaust port...ill try to get pics .
bore is 64.5
Edited by Jaystre
if the "break" is obviously a material failure ( just snapped off)  then can be a lot of things...
if its sand blasted off or blown off  melted off etc  its DETO>
i have seen SOME heads blow out where the o-ring seals from to much internal pressure or bad dome design, and/ or weak ass head studs.    the banshee stock head pattern has a very weak inherent problem in that area.  the dome just does not have the same sealing pressure that the rest of the head has.
Still no pics? Was it torqued properly? Oring might have blown and let water on a hot dome??? But that usually causes deto and other damage so I guess we're back at square one. Had this motor been run for a while or was it a new build? Maybe the deck wasn't square?
