Big Bore dome angle question
If we were not distracted with your fucked up english you might get usefull answers. do you currently own domes of the correct bore and cc but for banshee pistons? if so do you own a lathe and have skills to use it? if any answer is no then go order domes set up for your motor. if all are yes then cut away. they probably wont turn out right and you will end up buying them anyway but the answer to your first question is yes. there is enough material in the done to switch angle and going from banshee to blaster you can keep the squish really close.
Yes my first question is if I can switch to a 9 degres if actually have 12* ( with the same dome, just customize (machined) it ) sorry for the english..
