35mm PWK idle screw modification
Ok just trying to be sure it's possible. I was looking at my new PWK's ad noticed the way that the idle screw port is mirrored on the other side of the carb. I was thinking about modifying one so the idle screw is on the right side of the carb for easier access. Any one done it? I am pretty sure it should be ok as long as I plug the other side. Where can I get a bit that acts like a small end mill to create that flat surface in the new bore where the sping seats?
I've seen those and in fact my buddy has one on his 450. I should see if the threads compare. Thanks for the idea. I get that for most riders the idle gets set once and that's it. But for guys like you and I that ride all winter as well, the up and down temps need to be compensated for a lot some times. Especially when the tepm goes up or down 10-20 degrees every time the weather changes in a day of ice racing.
Are we talking Idle speed adjustment or air screw adjustment? I can adjust my idle speed with my fingers. I use a pair of FAST's metal idle speed screws. I don't really like to mess with the idle speed to much because your really should re sync the carbs once you make an adjustment.
This guy sells a finger adjustable air screw but it has to be purchased with his carb mod. His carb mod is a divider in the throat of the carb. That way a larger carb acts more like a smaller carb at part throttle.
http://www.rb-designs.com/pwk-carb-acc.htm
You would need to clamp it at the correct angle or use a mill. this way you can mill a flat spot like you talk about. probably center drill it and then drill it out slowly so the bit doesnt walk.
That's about how I saw it go in my head. Think its possible to use a small end mill in a drill press after pre drilling the bore for the seat? Just get it close then finish that last millimeter or so
