yamahaBanshee01 Posted September 30, 2013 Report Share Posted September 30, 2013 So i came home, decided to disconnect my TORS, disconnected the parking brake sensor, and started up, my left pipe was starting to backfire and it the bike bogged out. I than just adjusted the idle screw on the side of the carb to stock(tightened it in and backed it out 2 rotations). I went to kick start it and its not even letting me kick it all the way over. Please, please any help or ideas on what i should do or what happened?! Im puzzled Quote Link to comment Share on other sites More sharing options...
BUILDER Posted September 30, 2013 Report Share Posted September 30, 2013 Does it kick at all or is the kicker stuck now? Quote Link to comment Share on other sites More sharing options...
yamahaBanshee01 Posted September 30, 2013 Author Report Share Posted September 30, 2013 It kicks a little bit, but doesnt go all the way Quote Link to comment Share on other sites More sharing options...
BUILDER Posted September 30, 2013 Report Share Posted September 30, 2013 Sounds like you better pull the head and look inside the cylinders. If it was backfiring out one side then died sounds like you seized a piston. Quote Link to comment Share on other sites More sharing options...
yamahaBanshee01 Posted September 30, 2013 Author Report Share Posted September 30, 2013 What would cause the piston to seize?? Quote Link to comment Share on other sites More sharing options...
Kendro Posted September 30, 2013 Report Share Posted September 30, 2013 Lean condition in the cylinder burns hotter and causes things to over heat. Also less oil enters the cylinder in a lean condition. Piston and or rings start to melt and then lock down the engine.The lean condition was probably the cause of the back fire in that cylinder. Quote Link to comment Share on other sites More sharing options...
BUILDER Posted September 30, 2013 Report Share Posted September 30, 2013 Yep what ^^^^^^^^^^^^^^^ said 1 Quote Link to comment Share on other sites More sharing options...
yamahaBanshee01 Posted September 30, 2013 Author Report Share Posted September 30, 2013 Even if the bike was only ran for a 30 seconds and bogged out, would cause it to overheat? What would cause it to become "lean"? Im sorry if im annoying you.. I just want to understand why this happened so i can prevent it in the future. Quote Link to comment Share on other sites More sharing options...
fappy'97 Posted October 1, 2013 Report Share Posted October 1, 2013 We can't tell you how to prevent it without knowing what happened. Pull the head, take pictures, and we'll be able to help more! Quote Link to comment Share on other sites More sharing options...
yamahaBanshee01 Posted October 1, 2013 Author Report Share Posted October 1, 2013 Is it possible the kickstarter can get jammed? Should i try and roll and down shift and see if itll start? Just wanna see my options before taking everything apart. Its just strange cuz it has always started the past couple weeks of me starting it and letting it run. It didnt bog out or nothing. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 1, 2013 Report Share Posted October 1, 2013 Should i try and roll and down shift and see if itll start? If you do, it'll end up looking like this. If it were mine, I would do things in this order. 1 Pull the stator cover and see what happens when you try to turn the flywheel back and forth BY HAND. 2 Pull the exhaust and look into the exhaust ports to see what the pistons look like. 3 If you don't see anything bad with the pistons, Consider pulling the clutch cover to see if there's a problem there. 4 If you're going to pull the top end apart, DO A LEAKDOWN TEST FIRST! Is there any chance you ran unmixed gas in it? 1 Quote Link to comment Share on other sites More sharing options...
yamahaBanshee01 Posted October 1, 2013 Author Report Share Posted October 1, 2013 ouch!! that looks like it hurt. lol i will do the order you stated when i get back from work tomorrow. ill keep you posted.. ill take pictures of the pistons and hopefully get an answer.. i remember when i bought this quad a few years back, the kid said it was bored.. i do not remember how much. would it be your best judgement, if one of my pistons are bad, to change both of them? if so, is their any size bore thats pushing the limits? or any specific brand to stay away from? if i end up rebuilding the top end.. i want to make it legit. and when i mean that, i don't mind spending more money on quality to end up getting the most HP i can get out of this shee. it always treated me right and i have a sick love for it that i wouldn't mind giving her a big makeover. Quote Link to comment Share on other sites More sharing options...
joey83 Posted October 1, 2013 Report Share Posted October 1, 2013 So i came home, decided to disconnect my TORS, disconnected the parking brake sensor, and started up, my left pipe was starting to backfire and it the bike bogged out. I than just adjusted the idle screw on the side of the carb to stock(tightened it in and backed it out 2 rotations). I went to kick start it and its not even letting me kick it all the way over. Please, please any help or ideas on what i should do or what happened?! Im puzzled It doesnt sound like you were messing with the idle screw. All the way in and out two sounds like your A/F mixture screw. Maybe you leaned it out right there? But I really dont know if it would melt down idling unless you just had it screwed all the way in. Listen to what everybody has said. It's exactly what I woukd do too. Do not tear the head off or without doing a leakdown first. Ask questions. Good luck. Quote Link to comment Share on other sites More sharing options...
yamahaBanshee01 Posted October 1, 2013 Author Report Share Posted October 1, 2013 It doesnt sound like you were messing with the idle screw. All the way in and out two sounds like your A/F mixture screw. Maybe you leaned it out right there? But I really dont know if it would melt down idling unless you just had it screwed all the way in. Listen to what everybody has said. It's exactly what I woukd do too. Do not tear the head off or without doing a leakdown first. Ask questions. Good luck. Hey joey, when you say leaned out, does that mean my piston breaking or what? i keep hearing the term and don't exactly know what that means, is it the cylinder wall thinning out and breaking? Quote Link to comment Share on other sites More sharing options...
J-Madd Posted October 1, 2013 Report Share Posted October 1, 2013 If you do, it'll end up looking like this. If it were mine, I would do things in this order. 1 Pull the stator cover and see what happens when you try to turn the flywheel back and forth BY HAND. 2 Pull the exhaust and look into the exhaust ports to see what the pistons look like. 3 If you don't see anything bad with the pistons, Consider pulling the clutch cover to see if there's a problem there. 4 If you're going to pull the top end apart, DO A LEAKDOWN TEST FIRST! Is there any chance you ran unmixed gas in it? I would do 1, then 3 if it where me. If I understood right, it was running fine before the TORS disconnect, then you fired it up and it was backfiring (but didn't ride it). You're not usually gonna do much damage to a motor if it was just idling or revving in neutral (UNLESS, as Starwriter mentioned, you put straight gas in it). The timing plate could have come loose (which would cause the backfire), or something on the clutch side. Quote Link to comment Share on other sites More sharing options...
