How much HP would my cylinder have
Well that's all I asked was to smooth the ports an clean it all up an no he did not know . What should I have done for the 4mil?
Ok, so if he didn't know that the motor was getting a stroker crank your motor is way off. Not just the porting, the head to. You have more stroke now so to work properly you need the ports adjusted to work with the new piston stroke. Then the head also needs to be chambered/milled as well. The piston crown will come out of the bore now so the head needs a recessed dome profile. It's a good thing that head isn't installed yet. Find a real builder and get the cylinders set up for the stroke and have them re work the head for proper clearance. And do not try to use a ghetto spacer plate to run the 4 mil.
