Juss11 Posted September 22, 2013 Report Share Posted September 22, 2013 (edited) So just looking for ideas? I have a 4mill dune port with long rod. Im going to be running 28mm PWKs,v4 reeds,t5,custom cut doms for pump gas & k&n pods, at sea level. So Kevin at herjuggs said to start with a 155/55 does that sound about right? Also what position should my needle jet be set at? I forgot to ask him. Edited September 22, 2013 by Juss11 Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted September 22, 2013 Report Share Posted September 22, 2013 that should be close. i would guess a little more on main, maybe start with a 160. what needle are you using? i usually start with needle in middle clip position. im running at sea level with a stock stroke motor 48/155 n68a needle vf4's will require a larger pilot jet Quote Link to comment Share on other sites More sharing options...
Juss11 Posted September 22, 2013 Author Report Share Posted September 22, 2013 I have to look and see what needles they are. So I do have some 158 mains, I will start with those. Thanks for the great advice Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted September 22, 2013 Report Share Posted September 22, 2013 Yep, that's a good starting point for sure. Don't forget about the other aspects of building an engine and tuning. 1st and foremost - Leakdown check 2nd Idle 1450 - 1550 rpm 3rd Carb Sync @ idle 4th Carb Sync @ 5500 rpms 5th Plug Chop Quote Link to comment Share on other sites More sharing options...
