Looking for a drag cylinders for 4 mil banshee!
Common24
No you can not just buy half of a case. You must buy both matched ends. They are machined together. You could get away with running mismatched cases for a little while but will eventually cause a lot of problems.
Pretty sure a super cub is 72-73 mm bore. cases are going to need to be bored for the larger sleeves to fit. just send off you cases to a builder to get bored and have them fix the studs. you will wrck the cases for sure if you do any more. there are tricks to get the studs out easily
