Common24 Posted September 21, 2013 Report Share Posted September 21, 2013 I am new to the banshee world and was running a hotrods long rod 4 mil setup with drag ported stock cylinders. I had one of my cylinders crack on me after I found out it was a doctored motor just to sell with 4 stripped studs. I am looking for a drag top end that would work best in 200ft dirt drags. If anybody has anything or info lets hear it thanks Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted September 22, 2013 Report Share Posted September 22, 2013 I got some 10 mill cub cylinders ..txm me 3145173663 1 Quote Link to comment Share on other sites More sharing options...
LCW Posted September 22, 2013 Report Share Posted September 22, 2013 I have a set of 4mil stock cylinders. You could bore to 66mm or have them honed and pistons matched. Quote Link to comment Share on other sites More sharing options...
Banshee520 Posted September 22, 2013 Report Share Posted September 22, 2013 I have a complete topend minus the head shell its a 4mm 472 supercub done by herr jugs racing. it has ran 5.90 at 101.33mph and I weigh232 comes with drag ported cylinders and pistons and rings 4mm hotrod crank reedcages that are cr125 cages and domes for 1500 plus the ride thanks brian Quote Link to comment Share on other sites More sharing options...
jayhawkatv Posted September 22, 2013 Report Share Posted September 22, 2013 i have some drag ported stock cylinders by f.a.s.t. I MIGHT part with. destroy most 4 mil cubs. Quote Link to comment Share on other sites More sharing options...
Banshee520 Posted September 22, 2013 Report Share Posted September 22, 2013 Ihave a complete topend minus the head shell its a 4mm 472 supercub that has ran 5.90 at 101.33mph in 500ft with a232lb rider .it comes with drag ported cylinders piston and rings 4mm hotrod crank cr125 reedcages and domes for 1500 plus the ride thanks brian Quote Link to comment Share on other sites More sharing options...
Common24 Posted September 22, 2013 Author Report Share Posted September 22, 2013 I am needing something fast send me some info and pics to (502)655-7445 Quote Link to comment Share on other sites More sharing options...
Coty23 Posted September 22, 2013 Report Share Posted September 22, 2013 For u banshee520 u need to your setup cuz i have a 4mil cub short rod 5.9 109mph Quote Link to comment Share on other sites More sharing options...
Common24 Posted September 22, 2013 Author Report Share Posted September 22, 2013 The crank I am running I was told was a hotrods 4 mil. The crank does say hotrods but also Ck158 hr204. Does anyone have any idea what crank this is short or Long rod? Quote Link to comment Share on other sites More sharing options...
LCW Posted September 22, 2013 Report Share Posted September 22, 2013 That's a long rod 4mil crank. Quote Link to comment Share on other sites More sharing options...
Common24 Posted September 22, 2013 Author Report Share Posted September 22, 2013 Will that work with any 4 mil setup Quote Link to comment Share on other sites More sharing options...
LCW Posted September 22, 2013 Report Share Posted September 22, 2013 Short rod and long rod are 5mm difference in length. More than likely they will have different pistons and different porting. Most prefer the long rod, as it is easier on pistons and cylinders. Quote Link to comment Share on other sites More sharing options...
Common24 Posted September 22, 2013 Author Report Share Posted September 22, 2013 Will banshee 520s kit work well with that crank Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted September 26, 2013 Report Share Posted September 26, 2013 His kit includes the crank .it comes with drag ported cylinders piston and rings 4mm hotrod crank cr125 reedcages and domes for 1500 plus the ride thanks brian You are going to need to port the case to match the cylinder though. Quote Link to comment Share on other sites More sharing options...
Common24 Posted September 26, 2013 Author Report Share Posted September 26, 2013 I bought the kit from him Monday. I should receive it tomorrow. My studs on my bottom case were stripped when I tried replacing them I had 4 break and now after spending hours trying to get them out of the case I am down to purchasing new case half or drill and heli coil. Can I just buy the top half of a case or do they really need to be bought in pairs? Quote Link to comment Share on other sites More sharing options...
