right side popping
Bennett131
ok so I have done a few searches on here cant find anything real conclusive but I am getting almost like a backfire out of my right pipe and its smoking a little more as well its not too noticeable but the noise its making is and it idles fine and it also runs fineI have done a leak down test its all good and I just replaced the plugs and got the same thing any ideas on what it could be? I am ordering my carb sync tool to check that btw
thanks for the help in advance
So you plugged off both exhaust flanges and one intake boot and pressurized the other intake boot and your leakdown results were good?
If so, then I'd start looking into cleaning the carbs and jets really good and also make sure your floats are set correctly.
What carbs and jets are you currently running?
And make sure fuel flow is not obstructed in any way.
I pumped air into my exhaust ports with the intakes plugged with my spark plugs in I put 7 psi into it and it dropped 1 psi in 20 mins and im running a 30 pilot and a 340 main I cleaned out the jets last night and put them back in and im running stock carbs with tors im going to eventually get new carbs so I wasn't that worried about getting rid of them
