Trenton Tigney Posted August 27, 2013 Report Share Posted August 27, 2013 Okay so I have a banshee with an athena 392 kit on it. My compression on the right cylinder is 120psi an on my left cylinder is 80 psi I'm guessing it has a leak in the left reeds somewhere but what should the compression be on a athena 392 kit . Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted August 27, 2013 Report Share Posted August 27, 2013 the reeds don't have anything to do with compression. you should have at least 125 on each side I would expect. time to inspect and find out why its low. headgasket or stuck rings maybe? another question is why did it loose compression? was it ran lean and hot because of an air leak? Quote Link to comment Share on other sites More sharing options...
Trenton Tigney Posted August 27, 2013 Author Report Share Posted August 27, 2013 I'm not exactly for sure I thought maybe the reeds cause there new an they couldn't get them to seal at first. I got this from another guy. Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted August 27, 2013 Report Share Posted August 27, 2013 Pull the cylinders, chances are you'll find pistons that are scuffed beyond belief, and the rings stuck or welded to the pistons.... More than likely it was ran lean.... It does not take long to destroy a 2 cycle engine from being ran lean... Less than an hour usually..... Quote Link to comment Share on other sites More sharing options...
Trenton Tigney Posted August 27, 2013 Author Report Share Posted August 27, 2013 Well the pistons on top are not scratched , I'm about to pull the jugs off . Any suggestions on tools to pull the exhaust springs off Quote Link to comment Share on other sites More sharing options...
Starwriter Posted August 28, 2013 Report Share Posted August 28, 2013 Vicegrips or a spring puller hook tool. Quote Link to comment Share on other sites More sharing options...
fappy'97 Posted August 28, 2013 Report Share Posted August 28, 2013 Of course they won't be scratched on the top Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted August 28, 2013 Report Share Posted August 28, 2013 Brilliant Quote Link to comment Share on other sites More sharing options...
Trenton Tigney Posted August 28, 2013 Author Report Share Posted August 28, 2013 Thanks for the help! Ill see the condition of the piston tomorrow! Quote Link to comment Share on other sites More sharing options...
Alba Racing Posted November 12, 2013 Report Share Posted November 12, 2013 Stock compression is 120ish. Id think you would have more. Quote Link to comment Share on other sites More sharing options...
Finch Posted November 12, 2013 Report Share Posted November 12, 2013 Stock compression is 120ish. Id think you would have more. not true here at 5000 feet they come out right about 100. Quote Link to comment Share on other sites More sharing options...
