73 bore 4 mil cheetha parting and more..
4mil cheetha ported by Dan Hull. Here's what I have left. :
Cylinders 73 bore, head, v-3 reeds with less than 20 passes, domes ( one has small pits), upp intakes and cases. Lower case half has been repaired (back corner on clutch side). Everything is in great shape, was complete running motor but the lower case half has been repaired. 875 shipped.
Also have:
N down 1-5 over ride cut by WCR 300 shipped
Billet clutch basket with stock gear and small kicker gear. Has little play. 80 shipped
Small flange out right side big bore chrome CPI's one repair on neck. 350 shipped
Small flange out each side big bore shear chrome, one small ding on neck 400 shipped
Three bar wheelie bar with adaptor for top bar to mount to stock frame, two lower bars mount to carrier bolts. Was set up for 8 over arm but top bar is slip.. 250 shipped
6 over swing round house Molly swing arm and Tyson wheelie bar ( no wheel) and strut 450 shipped
I have pics of all can text them.
804 426-1562
UPDATE WITH PICS.
http://s319.photobucket.com/user/blazen582/library/Cheetah
Cylinders 73 bore, head, v-3 reeds with less than 20 passes, domes ( one has small pits), upp intakes and cases. Lower case half has been repaired (back corner on clutch side). Everything is in great shape, was complete running motor but the lower case half has been repaired. 850 shipped.
Also have:
39 PWK's alky Carbs, cable, billet throttle, filters, and pump  320 shipped
K&T billet pegs spacers and bolts   Right has mark from lock up clutch cover see pic. 65 shipped..
Trinity stage IV billit adjustable timing plate 30 shipped.
 Brand new K&N filters and otter wears Bought for 38-40 carbs.  60 shipped
Small flange out right side big bore chrome CPI's one repair on neck. 325 shipped
Three bar wheelie bar with adaptor for top bar to mount to stock frame, two lower bars mount to carrier bolts. Was set up for 8 over arm but top bar is slip.. 200 shipped
Can call or text
804 426-1562
UPDATE 2 with pics. If its not listed its sold..
http://s319.photobuc...library/Cheetah
Can call or text
804 426-1562
  • 1 month later...
