NVRDNE2008 Posted August 21, 2013 Report Share Posted August 21, 2013 Hey guys I'm new to here but not to the quad world I've owned a yfz450 for 7 years and recently picked up a banshee. i found some a arms on here for pretty cheap so I picked the, up too. I'm not sure who makes them but they are really well made. The bushing size was different than stock so I made my own at work and ordered some new ball joints and tie rods. Installed them yesterday and started adjusting but can't seem to get it right. I've tried every combination I can and this one is the only one that works. Does this look right to you guys or am I missing something? Any input will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted August 21, 2013 Report Share Posted August 21, 2013 That's way too much caster. Obviously the caster isn't adjustable on those arms. The lower arms have to be right. Is it possible that the upper arms need to be swapped side to side? Quote Link to comment Share on other sites More sharing options...
NVRDNE2008 Posted August 22, 2013 Author Report Share Posted August 22, 2013 I tried swapping the upper arms but they hit the shocks. Ill try tomorrow and post some pics. I wish I knew who made them so I could contact them. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted August 22, 2013 Report Share Posted August 22, 2013 That's some pretty unique bracing on the lower shock mount. Surely somebody on here knows what they are. If nobody chimes in, start an "identify these arms" thread. Quote Link to comment Share on other sites More sharing options...
NVRDNE2008 Posted August 22, 2013 Author Report Share Posted August 22, 2013 Ok will do, thanks for the help Quote Link to comment Share on other sites More sharing options...
toytech Posted August 22, 2013 Report Share Posted August 22, 2013 with the way the angled cross braces are on the lower arms, it would be stronger if the lower arms were on the opposite sides, try switching the lower arms side to side. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted August 22, 2013 Report Share Posted August 22, 2013 with the way the angled cross braces are on the lower arms, it would be stronger if the lower arms were on the opposite sides, try switching the lower arms side to side. The shock mounts are not centered between the pivot bushings (front to rear), so there's no way the shocks would mount up. Quote Link to comment Share on other sites More sharing options...
NVRDNE2008 Posted August 22, 2013 Author Report Share Posted August 22, 2013 Yup already tried swapping the lowers and it puts the shocks in a bind. Quote Link to comment Share on other sites More sharing options...
bebetekbanshee358 Posted August 24, 2013 Report Share Posted August 24, 2013 Drag arms maybe. Caster is good for straight line drags Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted August 24, 2013 Report Share Posted August 24, 2013 Put tires on it and set the caster while its at ride height....they should be fine Quote Link to comment Share on other sites More sharing options...
springer Posted August 25, 2013 Report Share Posted August 25, 2013 Drag arms maybe. Caster is good for straight line drags that amount of caster would aid in going in a straight line, but those sure are beefy looking for a drag arm. although that does look excessive, throw it together and see how it rides. in theory, it will of course be more of a fight to turn and stuff, but it may not be that bad. i built a lot of caster into my drag frame arms and never really noticed a "difficult" turn. of course i wasn't going through the trails, but i didn't really notice anything weird. Quote Link to comment Share on other sites More sharing options...
