wright2383 Posted August 21, 2013 Report Share Posted August 21, 2013 (flame suit zipped up tight) So my 03 banshee came with a 2 in 1 dynoport exhaust. Ive searched, read, searched again, and read some more and it seems the general consensus is that the dynoport pipe sucks. My question is, for my setup which will be a 440 exciter intake manifold, and a 40mm Lectron carb, are Pro Circuits the right pipe? I will be riding 90% + on wooded trails. I know you all will tell me to get the PC's, and that brings me to my next question. Are the PC's really a 500-600$ improvement over the dynoport? Are PC's the worth the cost of replacing the dynoport or should I be spending the money elsewhere to start out (no im not interested in running dual carbs at this time) Thanks for the help, and try to take it easy on my 2 in 1 carb setup, and lectron choice (seems you guys dont like those either, but Im looking for simplicity) Quote Link to comment Share on other sites More sharing options...
wright2383 Posted August 21, 2013 Author Report Share Posted August 21, 2013 your jugs ported? if not, that carb is way too big. by the dynoport isn't really that good. i would suggest a cheap set of fmfs, wont cost a lot. and 500-600 is way overpriced for PC, try find a used set. No porting, stock motor. 40mm is what the guy at Lectron suggested. Said they have run single 40's on Banshees for years with good results. The 500-600$ price was the best i could find for a new set of pipes with type 296 silencers (I have to have USFS approved spark arrestors for the state trails i ride (they DO check) If a single 40 is too big, what size lectron do you suggest? Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted August 21, 2013 Report Share Posted August 21, 2013 Yikes. Get a smaller pwk carb. I run a 33mm. First off what's the main use for this bike? Drag, woods, dune? Quote Link to comment Share on other sites More sharing options...
wright2383 Posted August 21, 2013 Author Report Share Posted August 21, 2013 (edited) Yikes. Get a smaller pwk carb. I run a 33mm. First off what's the main use for this bike? Drag, woods, dune? my banshee has a single pwk33 on it right now with a trinity 2 in 1 that i will be swapping for the exciter 440 manifold (and maybe some new reeds / cages while im at it). Ive done a lot of reading on the Lectron, and i want to try it back to back against the pwk. i will be riding like 90% woods / trail, (state forest trails in PA) also the pro circuit thought was based on this thread http://bansheehq.com/forums/index.php?showtopic=105993 Edited August 21, 2013 by wright2383 Quote Link to comment Share on other sites More sharing options...
lms1977 Posted August 21, 2013 Report Share Posted August 21, 2013 I ran the dynoport with trinity 2 into 1 carb 35 pwk and liked it that being said I would not run it again a set of fmf and stock carbs seems as good and more power. but that being said not 600$ worth better. now that I got away from the 2 into 1 stuff I would never recommend it to anyone even in the woods. I did try a shearer 2 into 1 never really jetted it right but it did seem way better on my motor than the dynoport. really depends how much you want to spend I would put the pwk on the other manifold and call it a day Quote Link to comment Share on other sites More sharing options...
BeeCanBanshee Posted August 21, 2013 Report Share Posted August 21, 2013 I know you said you wanted to keep the 2-1 carb thing but I would ditch it. I had one with a 33pwk and fatties ran good but then switch to dual stock carbs and felt an improvement across the board,more bottom end way more top end and better throttle response. But if you must keep it sell the pipe buy used PC's and get a port job. Quote Link to comment Share on other sites More sharing options...
lms1977 Posted August 21, 2013 Report Share Posted August 21, 2013 you had a shearer 2-1? hmmm. yea I got it to try from east coast atv I posted on it in a thread here Quote Link to comment Share on other sites More sharing options...
wright2383 Posted August 22, 2013 Author Report Share Posted August 22, 2013 just picked up a clean set of FMF gnarlys with powercore silencers on ebay. Thanks for the input guys! Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted August 22, 2013 Report Share Posted August 22, 2013 off a ebay store? Quote Link to comment Share on other sites More sharing options...
wright2383 Posted August 23, 2013 Author Report Share Posted August 23, 2013 off a ebay store? yes, i hope i didnt screw up. for the pipes and silencers it was about 275$ with about 30$ for shipping. I looked around and i think i saved about 150-200$ over new, and the set i got looked pretty good. no rust, dents or dings. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 23, 2013 Report Share Posted August 23, 2013 That's great for shipping pipes. As for carb size, a 34-36 taper bore lectron would be pretty bitchin on your set up. Quote Link to comment Share on other sites More sharing options...
wright2383 Posted August 23, 2013 Author Report Share Posted August 23, 2013 That's great for shipping pipes. As for carb size, a 34-36 taper bore lectron would be pretty bitchin on your set up. thanks!!! the lectron guy said 40mm, but after ALL of you guys saying to go smaller, I will do just that. Question, Will the taperbore be any better for low end? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 26, 2013 Report Share Posted August 26, 2013 Should be Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted August 28, 2013 Report Share Posted August 28, 2013 (edited) Start off by ditching the pipe, going to a good set of twin mid pipes will benefit the most for the bucks spent. After that if your not satisified, make the next step. Edited August 28, 2013 by Snopczynski Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted August 28, 2013 Report Share Posted August 28, 2013 Start off by ditching the pipe, going to a good set of twin mid pipes will benefit the most for the bucks spent. After that if your not satisified, make the next step. What do you know? Quote Link to comment Share on other sites More sharing options...
