Carbs...
chilled
Stock carbs are 26mm, and unless you have a huge cc motor, that is way too much carb.   They are also round slides, which aren't the best.  I've got a stock cylinder 4 mil, and these are what I'm using.  They perform better, and are quite a bit cheaper, than the ones you found.
http://www.amazon.com/Mikuni-TMX-Flat-Valve-Carb/dp/B000GV2D7G
i have pwk28's on my stock cylinder 4min stroker.
smaller carbs help retain to bottom end,  when you go to a larger carb, you will loose some bottom end and gain some top.  thats why drag guys always run huge carbs.
  • 2 months later...
