troubles starting after full build
so  finally put everything together and got my required parts for my carbs. i have spark for sure, but im not sure if im getting gas. the carbs are clean and a fresh rebuild so i dont hink thats the issue. is it my reeds? i think i need to do a compresion test. figured id ask here for any thoughts
Edited by slimguy379
Check the screens in the tank, on the fuel shut off.  Also, make sure that your vent hose isn't blocked.  If the steering stem is full of water, and the end of the hose is in the water, the tank will not vent properly.
Edited by fastbanshee8
did a compression check, seems fine for a new build. NO clue how but i had lost spark again due to a ground. but re wired and tinkered with the carb to get full gas bam runs like a kitten. only thing is i need to hold on the throttle to keep her alive. spark plug just looks wet no black or white. i have a stock pilot but a 330 main, i did research on the jetting forum and from what i can tell thats apprriate. the air screws are 1 1/2 - 2 turns out. what could be my issue?
