Alex_o345 Posted August 15, 2013 Report Share Posted August 15, 2013 Hey guys, I have an 01 shee with FMF Fattys, K&N Air Filter with no airbox lid, TORS eliminators and thats about it everything else is stock as far as I know. From what I've read I should be using 280s - 300 main jets. But when I put in anything that big it wont even hit powerband it just boggs HARDD. I had to keep the stock 200 mains in and put the needle clip on the 5th position (closest to blunt end) and it was running good for a bit but still seems to be a little rich. So I put 190's in and had the airscrew 2 turns out and all of a sudden it start pulling like crazy the best its ever ran. Went for 2 rides and on the 3rd it started to hesitate at WOT and didn't feel like it was pulling as much. So first off I was wondering if there's something that could be requiring me to run the bike so lean? After an hour ride when I had it running good with the 190s the plugs were nice and brown so I don't think it was too lean. Everyone i've told this is amazed that my bike hasn't blown up yet -- so I don't understand what's different about mine. I hear the float height could cause rich symptoms but is there anyway that could be it? I've never really checked them because it never leaked gas. And what can I do about the hesitation at WOT there's no way I have to go to a 180 is there? One other thing is my compression is just under 115 on both sides could that be causing my problem? Its been like that the whole time I've had it -- 2-3 years. Any knowledge would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
kedge82 Posted August 16, 2013 Report Share Posted August 16, 2013 what elevation are you at? you should diffently do a leak down test that well make u run rich with the fmfs and k@n air filters you should be at least 260 mains to 300 i have fmf sst with k@n air filters open box and carbon fiber reeds and run 270s at 850 ft elevation between 60 and 90 degrees. i would say that somewhere u have an air leak though Quote Link to comment Share on other sites More sharing options...
Alex_o345 Posted August 16, 2013 Author Report Share Posted August 16, 2013 I'm at 350ft and about the same temp, 60-80. I will forsure do airleak test tonight. For that is the best way to let it idle and spray carb cleaner around the boots and carbs to hear if idle increases ?? Quote Link to comment Share on other sites More sharing options...
kedge82 Posted August 16, 2013 Report Share Posted August 16, 2013 there is an actull kit u can buy and u ad air to it to see if holds psi or u can vacuum it it can have leak from more than just carbs exp. head looose jugs not tight broke seal lots of things and any one of them can cause it to get air top laces theres not suppose to be Quote Link to comment Share on other sites More sharing options...
pickerg1 Posted August 20, 2013 Report Share Posted August 20, 2013 What brand / type of carbs are on that thing? You sure they are stock? Sounds to me like you have different carbs on that thing if you're at a 190 main jet and it isnt lean as hell. Quote Link to comment Share on other sites More sharing options...
pickerg1 Posted August 20, 2013 Report Share Posted August 20, 2013 one more thing, what kind of compression tester did you use when you got 115psi ? There are some major variances amongst those things so you could be closer to 90 psi on another compression tester. I'd find someone with a snap on compression tester or take it to a shop that has one and let them do a compression test on it. - 2 cents. Quote Link to comment Share on other sites More sharing options...
Alex_o345 Posted August 20, 2013 Author Report Share Posted August 20, 2013 yah its forsure the stock Mikuni carbs. The compression tester I used is one that screws in -- probably not the best. I will try bringing it to a shop it test it again. And try and find someone with a leakdown tester to see if everythings up to par. Maybe it could just use a fresh top end -- really nothing else it could be eh? Thanks for the suggestions. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 21, 2013 Report Share Posted August 21, 2013 My guess is electrical system not burning the fuel Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted August 21, 2013 Report Share Posted August 21, 2013 Or one helluva dirty air filter. What are symptoms of worn reeds? Quote Link to comment Share on other sites More sharing options...
Pastrykiller Posted August 22, 2013 Report Share Posted August 22, 2013 Been down this road as well. Went from a stock cylinder with t5's to a dune port with t5's. put it on shearers dyno and it pulled 56 Hp with 200 mains and 27.5 pilots. Motor is solid with no leaks and just didn't like anything over 200 mains and it had the stock airbox with pro adapter filter. Quote Link to comment Share on other sites More sharing options...
Alex_o345 Posted August 27, 2013 Author Report Share Posted August 27, 2013 Been down this road as well. Went from a stock cylinder with t5's to a dune port with t5's. put it on shearers dyno and it pulled 56 Hp with 200 mains and 27.5 pilots. Motor is solid with no leaks and just didn't like anything over 200 mains and it had the stock airbox with pro adapter filter. And its still running strong? Quote Link to comment Share on other sites More sharing options...
Pastrykiller Posted August 27, 2013 Report Share Posted August 27, 2013 Yes sir. Quote Link to comment Share on other sites More sharing options...
