bluebanshee98 Posted August 20, 2013 Report Share Posted August 20, 2013 or any site sponsor should have them. id recommend redline racing. if the previous owner had pipes reeds and after market filter and didnt rejet to what it should be then thats bad. you could be super lean and chance blowing up the motor. make sure you see what jets are in there first. if your under 2000ft elevation then a good starting point would be 280 mains and 30 pilots needle mid clip in stock carbs, 1.5 turns out on air screw and see how it runs. you are running a air box right? and no lid? Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted August 20, 2013 Report Share Posted August 20, 2013 I just tuned my 02 this weekend. I'm at sea level. T5's, Chariot Reeds, Chariot Intakes, +4* on the plate and I run 36:1 w/91 octane. Stk carbs w/pods and no TORS 27.5 pilots air screw 1.5 turns out stk needle middle cllp 300 mains You are right, 30 pilots, but I'd bump up the mains to 300. 280's might be too lean for VF4's and FMF pipes. I did a plug chop and it was perfect, but barely... Probably can go up to a 310 main, but I'm gonna rock it as is. If it burns down, which I doubt, then it's time for a new top end and an aggressive MX port job! Quote Link to comment Share on other sites More sharing options...
TORONTO TROY Posted August 20, 2013 Author Report Share Posted August 20, 2013 You guys have a store for everything. Quote Link to comment Share on other sites More sharing options...
TORONTO TROY Posted August 20, 2013 Author Report Share Posted August 20, 2013 TORONTO is 250 ft above sea level. What would be a good starting point? Fuel is iponi 32to1 Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted August 20, 2013 Report Share Posted August 20, 2013 Are you running a air box? If you have no leaks 280 mains should be fine for warm weather but if you have pods your gonna have to bump up the mains like strm trpr said Quote Link to comment Share on other sites More sharing options...
TORONTO TROY Posted August 21, 2013 Author Report Share Posted August 21, 2013 (edited) I have the K&N filter in the air box with the K&N air box cover,it's warm now but fall is pretty cool up here between 3 and 15 C I will try your setup for sure and will let you guys know what happens. Edited August 21, 2013 by TORONTO TROY Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted August 21, 2013 Report Share Posted August 21, 2013 F.A.S.T. http://www.farmandsandtoys.com/ Cascade http://www.cascadeinnovations.net/store/store_view.cfm?store_area_id=13&STORE_DEPT_ID=102 Or, since you're in Canada, you can go to your local Yamaha stealership. Stock carb pilot jets are Banshee specific. Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted August 21, 2013 Report Share Posted August 21, 2013 Do you have the TORS eliminated? Do you have idle screws installed? There should be a hose that connects the two carbs together right between them. Carbs need to be sync'd with a sync tool that can be bought at FAST. Quote Link to comment Share on other sites More sharing options...
TORONTO TROY Posted August 21, 2013 Author Report Share Posted August 21, 2013 Carbs are in sync screws and everything are stock. Quote Link to comment Share on other sites More sharing options...
