Baluarte7 Posted August 12, 2013 Report Share Posted August 12, 2013 I just bought an 2007 stock banshee, it was running great, starting at the first kick... after been riding a little while it turn off and didn`t want to star by kicking, only pushing and it starts in less than 3 foots and have the same power.. what could happened? Quote Link to comment Share on other sites More sharing options...
Sandking Posted August 12, 2013 Report Share Posted August 12, 2013 You forgot your premix Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted August 12, 2013 Report Share Posted August 12, 2013 Plugged pilot jets. Clen entre fuel system. Tank, petyourcock, carbs, report back. JMHO, your results may, and will vary. Quote Link to comment Share on other sites More sharing options...
MarineNYC Posted August 12, 2013 Report Share Posted August 12, 2013 Gotsta fix dats der motars. 1 Quote Link to comment Share on other sites More sharing options...
1CrazyBastard Posted August 12, 2013 Report Share Posted August 12, 2013 Haha some of the responses made me ..Ok have you done a compression test ? If not I would be certain to do this first off so we know if the engine is hurt or not .If you don't have a compression tester buy or borrow one and check it .If the compression is good then check the spark which if you say the power is the same than the spark is probably fine but check it anyway .If you have comp and good spark it sounds like time to pull those carbs .and have a look and possibly clean and soak but " don't waste your time on anything til you verify your compression is ok " Quote Link to comment Share on other sites More sharing options...
oldskool Posted August 13, 2013 Report Share Posted August 13, 2013 ^^^^^^^THIS^^^^^^ Quote Link to comment Share on other sites More sharing options...
camatv Posted August 13, 2013 Report Share Posted August 13, 2013 easy! Quote Link to comment Share on other sites More sharing options...
