sean10 Posted November 3, 2003 Report Share Posted November 3, 2003 I went to Dumont this weekend and my bike seemed to fire up when ever it wanted to. I would kick it over 20 or so times and not start. Than i would wait a min. or two and kick it again and it would fire right up! The jetting in the bike has been the same for 12 years, so it cant be the jetting. I was just wonder if it could be the cdi because i only have gone threw one cdi in all my bikes and im not sure what the symptoms could be. Thanks in advance if someone can help! Quote Link to comment Share on other sites More sharing options...
kenr74 Posted November 3, 2003 Report Share Posted November 3, 2003 You may have clogged your pilots over time. If you ran some old gas it could have clogged them up. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted November 3, 2003 Report Share Posted November 3, 2003 Clean the carbs thoroughly and check the wires going on the coil (orange and black)make sure you have a nice connection. Also is the tors still on?? Little black box above the left exhaust?? Maybe try disconnecting the black/white striped wire coming from the on/off switch on the handlebars, there is a connection towards the gas tank. Disconnect it and that'll disconnect the ground that the on/off switch uses to kill the motor. I've seen those switches go after about 5 or so years.... Quote Link to comment Share on other sites More sharing options...
. Posted November 4, 2003 Report Share Posted November 4, 2003 have you put new plugs in? I had a screw on top plug doing that, and I was riding once and the one side cut out. Pulled the plug cap off and the screw on tip was still attached to the plug cap. Damn thing actually stripped. Luckily I could put it on upside down and make it back to camp. Quote Link to comment Share on other sites More sharing options...
sean10 Posted November 5, 2003 Author Report Share Posted November 5, 2003 Thanks guys for the help, but i put new plugs in, a new clutch, i have 34mm pjs on there so there isnt any tors and ive cut the key switch wires about 4 years ago. I think its the cdi so im going to take it off my wifes and try that. Thanks again. Quote Link to comment Share on other sites More sharing options...
