89mustang Posted August 8, 2013 Report Share Posted August 8, 2013 I've searched on here couldn't get a deffinate answer. If I get an adjustable timing plate do I have to run race gas? I live at 650' elevation mods currently are t-5's and a cut air box lid. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 8, 2013 Report Share Posted August 8, 2013 Nitro meth only Quote Link to comment Share on other sites More sharing options...
89mustang Posted August 8, 2013 Author Report Share Posted August 8, 2013 Oh I was gonna change it so I could run E85 Quote Link to comment Share on other sites More sharing options...
Young Guns Racing Posted August 8, 2013 Report Share Posted August 8, 2013 I've searched on here couldn't get a deffinate answer. If I get an adjustable timing plate do I have to run race gas? I live at 650' elevation mods currently are t-5's and a cut air box lid. No, ignition timing has nothing to do with compression and therefor the required octane of your fuel will not be affected by the timing plate. Quote Link to comment Share on other sites More sharing options...
89mustang Posted August 8, 2013 Author Report Share Posted August 8, 2013 Thank you for your help. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 8, 2013 Report Share Posted August 8, 2013 No, ignition timing has nothing to do with compression and therefor the required octane of your fuel will not be affected by the timing plate. Incorrect...to a point. A modest increase of timing should not need higher octane. But any time you increase heat in a motor (compression, timing, etc.) the possibility is there. If you slap on a plate and put a few degrees of timing on it...****And it was tuned/jetted properly before***...you most likely will not have to add octane. Listening to your motor and reading spark plugs are a good idea regardless. 1 Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted August 8, 2013 Report Share Posted August 8, 2013 +4 timing and always run premium fuel, you should have no problem... 86 and 87 octane are for lawn mowers anyway, and should never be run in your Banshee.. Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted August 8, 2013 Report Share Posted August 8, 2013 And E85 is for a Prius not a Banshee Quote Link to comment Share on other sites More sharing options...
toytech Posted August 8, 2013 Report Share Posted August 8, 2013 prius runs on 87 octane not e85 Quote Link to comment Share on other sites More sharing options...
Uf21 Posted August 8, 2013 Report Share Posted August 8, 2013 What fuel do you guys use on youre banshees? I always put 98ron fuel and it has stock cool head and stock timing plate. I always read guys saying they put 91ron fuel and if they get 21cc domes they go up to 95 or 98ron is this correct? Quote Link to comment Share on other sites More sharing options...
89mustang Posted August 9, 2013 Author Report Share Posted August 9, 2013 Thank you for all your replies. I'm more familiar with supercharged mustangs than the banshee's. I know more compression equals running race gas but low compression supercharged /turbo motors can also require it because of igmition timing.The E85 comment was a smartass comment on the nitro methane comment Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted August 9, 2013 Report Share Posted August 9, 2013 And E85 is for a Prius not a Banshee aaaaannnddddddd this guy is a mechanic, by trade. I guess now we know where NOT to go for that oil change. 1 Quote Link to comment Share on other sites More sharing options...
Nieskes Posted August 9, 2013 Report Share Posted August 9, 2013 What fuel do you guys use on youre banshees? I always put 98ron fuel and it has stock cool head and stock timing plate. I always read guys saying they put 91ron fuel and if they get 21cc domes they go up to 95 or 98ron is this correct? depends on your compression ratio... Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted August 12, 2013 Report Share Posted August 12, 2013 what pruis runs on e85? I have a customer with 2 Prius's and he runs E85 in both of them... So... Theres that....... Also have a customer with a "Not so" Smart Car that runs E85... Quote Link to comment Share on other sites More sharing options...
