sick421 Posted August 8, 2013 Report Share Posted August 8, 2013 I have a banshee with stock carrier and swing arm, im installing a RAD billet stock style carrier , everything bolts up good exept the caliper it doesnt line up with the carrier holes . The top hole does but the bottom doesnt its off by an inch , it seems like the brake rotor is too big and doesnt let the caliper sit far enough to line up. I say the rotor is big because on my other banshee the rotor is smaller it measures about 8 1/2 inches but that bike has a +4 round house swinger with brake stay . My question is does other smaller brake rotors fit the banshee hub ? I know if i swap the smaller rotor to the other bike the caliper will bolt right up , i just need to know what other rotor fit for example offf the 250r or something so i can purchase another rotor . Quote Link to comment Share on other sites More sharing options...
Starwriter Posted August 8, 2013 Report Share Posted August 8, 2013 I'm not quite sure what you've got going on, but a stock rotor is 8 5/8". So, are you saying that the rotor that you're trying to use is bigger than that? If so, it appears that you just need a Banshee rotor. Quote Link to comment Share on other sites More sharing options...
sick421 Posted August 8, 2013 Author Report Share Posted August 8, 2013 Ok so that means im backwards then the stock shee im working on has a larger rotor from another bike and my roundhouse shee has the correct size . But what i dont understand is why would everything work fine and bolt up good to the stock carrier with that larger rotor Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 8, 2013 Report Share Posted August 8, 2013 All year banshee's use the same rear rotor, you'll have to look close to figure out whats been changed. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted August 8, 2013 Report Share Posted August 8, 2013 Post some pics of what your talkin about. Sent from my SGH-T679 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
