stupid question
the angled cut out needs to face the airfilter... Look on the slides and about 3/4 the way up the slide on the side you'll see a small hole... That hole needs to line up with/be facing the small clear window on each carb... The holes won't line up with the windows unless it's at wide open throttle... But you'll be able to see where they need to be... Don't forget to re-sync the carbs after you install them completely
