coalhillking Posted August 5, 2013 Report Share Posted August 5, 2013 My banshee leaks coolant out of the hose below the radiator cap after only five minutes of riding. It doesn't seem like its over heating. What can make this happen? Could it need a new radiator cap? It's not leaking out of the cap Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 5, 2013 Report Share Posted August 5, 2013 the cap has two seals, one above the hose and one below, Yes get a new cap. Quote Link to comment Share on other sites More sharing options...
coalhillking Posted August 5, 2013 Author Report Share Posted August 5, 2013 Thank you ill try that and see what happens Quote Link to comment Share on other sites More sharing options...
VoOK Posted August 5, 2013 Report Share Posted August 5, 2013 Had the same thing happen to me months ago. Turned out to be a bad head gasket. Quote Link to comment Share on other sites More sharing options...
coalhillking Posted August 5, 2013 Author Report Share Posted August 5, 2013 I was kinda thinking that. I pulled the plastics off this morning and followed the line that its coming out of. It's the one that comes out of the top of the overflow tank. It drips down on the right side a arms. I want to get a noss cool head so guess that's next on the list Quote Link to comment Share on other sites More sharing options...
onlyonelife79 Posted September 16, 2013 Report Share Posted September 16, 2013 the cap has two seals, one above the hose and one below, Yes get a new cap. What do you mean when you say the cap has a seal above and below the hose ? Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted September 17, 2013 Report Share Posted September 17, 2013 What do you mean when you say the cap has a seal above and below the hose ? What he's trying to say is......There is a seal above and below the overflow hose. The cap seals to the smaller hole down in the radiator as well as at the flange of the cap. Quote Link to comment Share on other sites More sharing options...
onlyonelife79 Posted September 22, 2013 Report Share Posted September 22, 2013 ok, so I realize I asked a dumb question, but I also just found that there was coolant dripping out of my right exhaust pipe. I pulled the cool head and found a broken O ring and signs of coolant. Is this most likely the issue why I would have the same coolant leak out of the hose in-between the radiator cap seals ?. My radiator cap "Appears" to be in god shape. Is there a way to diagnose a radiator cap or just buy a new one ? obviously I am installing a new O ring and a new dome now that it got eaten up. Quote Link to comment Share on other sites More sharing options...
