Never Touching It Again!
vussute
Hi, got a question.
I recently took off my fmf sst pipes and the 260 jet screws and put back on my 200 jet screws and my stock pipes ( dont ask!) and now my bike wont kick over!
Everything is back in, made sure screws were clean etc. My idle screws are set back to 1 and a half turns and once i roll started it and it started but then started to bog out and the response was not touchy and took a long reaction time after i pressed the throttle and took about 2 seconds to actually do something and then just bogged out! I got brand new spark plugs in it not even ridden on.
any suggestions greatly appreciated. Thanks in advance.
Nope, it runs between the carbs in the center. If you take your seat off you should see a short approx 3 or 4 inch piece of tube that goes from the center of the right side of the left carb to the center of the left side of the right carb. :blink:
Also, if you took your slides out, you may have put them in the wrong carb, but I'm guessing choke tube also.
nah i checked the choke tube on and it was disconnected. Wher edoes it connect to?
There should be two little "bosses" that are used to connect the two carbs together. On the left carb it will be directly in line with the choke lever. On the right carb, it will be facing the left carb. If not in place it will cause the right carb to run very lean.
