mxturd Posted July 28, 2013 Report Share Posted July 28, 2013 We ride alot of ATV rodeos, here in Missouri, and I just put some 18 inch tires on my bike. My question is about gearing for the tires, mods are in my signature. Our rodeos are a 5 event reace, 4 of the evens are basically different barrel configurations that you negotiate and for time, the last event is bracket drag race. I have stock gearing now, but with the tire change should I go up a tooth on the front or ? Anyone that may have experience with 18 inch tires please help. Thanks Quote Link to comment Share on other sites More sharing options...
Young Guns Racing Posted July 28, 2013 Report Share Posted July 28, 2013 This is going to be more of a test and tune thing for you now. Snaller rear tire will make on revolution fasyerthsn ur 20in tire so u are gaining a small ammount of bottom end. It depends on what you want out of ur setup. I have a 2012 yfz450r as well, tons of mods and shes makin 52hp at the wheels. Way betyer than stock, I also dropped a tire size and to help wil spinning so much out of the gate I slapped on a +1 front sprocket Quote Link to comment Share on other sites More sharing options...
mxturd Posted July 28, 2013 Author Report Share Posted July 28, 2013 So with switching to 18s from 20 I already in a sense loweredd the gearing. I noticed it winds up really quick and alot of wheel spin I suppose Ill try a tooth higher in the front. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 28, 2013 Report Share Posted July 28, 2013 So with switching to 18s from 20 I already in a sense loweredd the gearing. I noticed it winds up really quick and alot of wheel spin I suppose Ill try a tooth higher in the front.This isn't my strong point, but there is a gearing calculator. Would suck if you switched the tires and changed gearing to be back at the same point. So figure out what you want to do and work with that Quote Link to comment Share on other sites More sharing options...
possum Posted July 29, 2013 Report Share Posted July 29, 2013 19-39 Quote Link to comment Share on other sites More sharing options...
