Please! I Need Help
Klotz
Please guys i really need your help on this.....i have pro circuits and love the top end...i just want a pipe with more low end but with the same top end or if posible more....should i sell the pcs and if i do what do i buy..please help....wpuld it help if you knew the riding i did!!
thanks
I agree, get a cool head and boost your compression, that'll help w/ the low end power your craving. If thats still not enough, then get a different set of pipes. You'll lose the high rev, but gain a lot of low end and midrange. You'll have more torque and be able to pull a higher gear to make up the top speed....Depends on your type of riding also. Whats the terrain you mostly ride on??
i like to race ppl and also ride a lot in the pits climbing big hills...and lately i have thoguht aslot obout cool heads...to get them should you put in new pistons right away or do they bolt on and the nos heads....are they just for nos or like recreational riding too....could you give me a site where i could look at these..thanks agian
www.nossmachine.com He's the guy that makes the heads, not for nos. Just like a pro design cool head but the look is a lot cleaner, uses the same domes, and he's a part of this forum to boot. His ad is at the top of the page when it goes through the ads.
I do the same type of riding and perfer the midrange pipes hands down. Your call though....
The head is inexpensive compared to a new set of pipes. Let me know if you are interested and I'll help with dome selection. I noticed that your timing is advanced. That, your elevation, and the type of fuel you want to run determine what compression you can go with. Increasing the compression will definitely improve your bottom end power.
-David
thanks for the help dave,...im looking into noss heads and then ill get back to you...should i buy them when i get a rebuild??or get them now...do they just bolt on.....
thanks
:D
It's a pretty easy mod. You only have to remove the fuel tank and drain the coolant to remove the stock head. You clean the top of the cylinders and install the new head. Re-jetting usually isn't needed but it's wise to check it after about any mod.
hey thanks agian...i just ave one more question about the install.....i dont have to rebuild to i...i can leave the pistons that i have in there now...cause i wont be needing a rebuild for a while i have lots of compretion......
i think im going to keep my pc's////thanks for the offer thoguh
shane
You don't need to rebuild the top end or replace the pistons to install an aftermarket head. If you stay with domes that provide a 'reasonable' compression increase, there are no problems using it on an internally stock engine.
